Radeon Software Crimson ReLive Edition 17.1.2 Release Notes
cageymaru
Radeon Software Crimson ReLive Edition 17.1.2 Release Notes.
http://support.amd.com/en-us/kb-art...mson-ReLive-Edition-17.1.2-Release-Notes.aspx
Article Number: RN-WIN-RADEONCRIMSONRELIVE-17.1.2
Radeon Software Crimson ReLive Edition is AMD's advanced graphics software for enabling high-performance gaming and engaging VR experiences. Create, capture, and share your remarkable moments. Effortlessly boost performance and efficiency. Experience Radeon Software with industry-leading user satisfaction, rigorously-tested stability, comprehensive certification, and more.
Radeon Software Crimson ReLive Edition 17.1.2 Highlights
Support For
  • Conan® Exiles Beta
  • Tom Clancy's Ghost Recon® Wildlands Beta
Fixed Issues
  • Changing memory clocks with Radeon WattMan with more than one display connected may cause memory clocks to intermittently become stuck at their minimum setting or switch between min and max ranges intermittently causing display flickering.
  • Diablo®III May experience smoke or lighting effects may appear corrupted when using DirectX®9 API.
  • Some applications may experience an intermittent or random runtime crash in atidxx64.dll.
  • FIFA®17 may experience a black screen on launch when using Hybrid Graphics or AMD PowerXpress system configurations.
  • Watch_Dogs®2 may experience an intermittent game crash after extended periods of play on some Radeon RX 300 series products.
  • Paragon™ may experience flickering in profile or store preview pages after changing graphics settings when using Multi GPU.
  • Forza Horizon 3 may experience a crash or application hang with the Blizzard Mountain DLC on some select Radeon GCN products.
Known Issues
  • A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background.
  • Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue.
  • Radeon RX 400 series products may experience scaling issues for some applications when using the display scaling feature.
  • Deus Ex: Mankind Divided™ may experience an application hang when running in Multi GPU with DirectX®12 and performing a task switch.
  • Mouse cursor corruption may be intermittently experienced on Radeon RX 480.
  • Counter-Strike™: Global Offensive has incorrect default slider values with Radeon Chill enabled. Users can modify these values to suit the experience they want.
Known Issues for Radeon ReLive
  • The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues.
  • Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products.
  • Radeon ReLive may stop working after hot unplugging of a secondary display.
  • Battlefield™1 may experience UI flickering and/or performance drops when recording gameplay with Radeon ReLive on graphics products with 4GB or less of VRAM.
  • Radeon ReLive recordings or overlay may experience flicker when creating a single recording for many hours.
  • Radeon ReLive may experience minor graphical corruption for the first few recorded frames when launching UWP applications.
  • Radeon ReLive will not allow recording settings to change with Instant Replay enabled. A workaround is to disable Instant Replay and change settings then enable Instant Replay.
  • Vulkan™ applications may experience a game hang when using Radeon ReLive to record.
  • Radeon ReLive will not notify an end user of low disk space during recording.
  • DayZ may experience an application crash when Radeon ReLive Instant Replay/Recording is active or the feature may not work as expected.
Package Contents
The Radeon Software Crimson ReLive Edition 17.1.2 installation package contains the following:
  • Radeon Software Crimson ReLive Edition 17.1.2 Driver Version 16.50.2711 (Windows Driver Store Version 21.19.413.0)
Cmon AMD, give me some sweet Vega!
Yes, i know, gigantic chance of them dropping the ball again.
while the drivers work very well,
my game profiles don't work well at all- for the past umm 4? major driver updates.
i turn off auto fan control and put the fan at ~2800rpm to keep it cool even under load (at that speed, the gpu is usually ~45c), however, most of the time said profile doesn't work, so i have to go under game settings, hit general settings, hit reset, then switch fan to manual, change the speed to~2800 then apply in order to have the fan actually,,,ramp up.
looks promising, hopefully they will already have optimized drivers for Vega when it is released.
thnx man! there should be a new version next week for the new games coming out. I saw it somewhere(yt) that amd said they'll have day1 drivers for "for honor" I think or maybe "wildlands" whatever comes out on the 14th.
