I am having some major problems getting the ATI drivers to work in Linux. I have tried 4 different versions, and keep getting the same result. I am using the driver for XFree 4.3.0 from ATI. com. First, I tried to use Mandrake 10.0. I could compile the drivers, but could only get 2D to work, no 3D. I then tried Mandrake 9.2 and 9.1. Same problem. On 9.2 I tried downgrading to XFree 4.3.0, the version the drivers were made for. Exact same result. No 3D. The error message says that there was an error, and that 2D will work, but 3D wont. After installation, I went to the ATI control panel, and it said the card was in PCI mode. Lastly I tried RedHat 9.0, with stock XFree 4.3.0. EXACT SAME RESULT! I never had any problems with NVidia's linux drivers. I did exactly what the instructions said. Anyone have any luck getting these to work? I will try just about anything! Everything I am doing is being done on the system in my sig.
