Radeon HD 6800 GPU load at system idle
tronester
About a month ago my HD 6870 started spinning its fan at full blast when I was away from the computer. As soon as I sat back down and moved the mouse, etc, the fan died down. I brought up the AMD control panel and watched it. The GPU load would go up super high when the computer was just sitting there, wasting power!
I tried a complete uninstall of the AMD software and drivers to no avail. Interestingly, if I just use the default drivers provided by windows, this problem does not occur.
Does anyone know how to fix this?
Right now the temp is 43 degrees C, but the load is zero because I'm using the computer. The core clock is 100mhz and fan speed 25%
All the drivers came directly from AMD.
I would try,
- scan for malware
- set monitor to never turn off (power settings)
- disable ULPS in Trixx
or
