Radeon HD 4870 Questions
Perini
1. How big are these things? Assuming the various manufacturers are making them in similar dimensions, does anybody have any info about the length of these cards?
I recently picked up a machine from Dell that was configured with the 8800 GT, so I figure as long as the 8800 GT will fit, the 4870 should fit as well. Unfortunately, I can't find the dimensions of either.
2. Which manufacturer is most reputable at this point? I see Diamond, Sapphire, and HIS all make them. Does anybody have a favorite?
Thanks in advance.
1. Its about 1/3 to 1/2 inch longer than a 8800GT, but shorter than 8800GTX and GTX 2xx
2. They're all pretty good. I usually buy Powercolor...
I think Visiontech is the choice with a lifetime warranty (from another thread).
