Ampersandle
- Mar 14, 2011
About a year ago, my computer was damaged somehow in transit. The motherboard was unusable but the graphics card, a Radeon HD 4800 series still seemed to work. Ever since then, though, it has a tendency to overheat easily. I have to manually set the fan to 100%, the GPU and memory clocks to lower than normal and turn down graphic detail in many games (TF2, Arma 2, even Guild Wars) otherwise it overheats and crashes the system.
I'm sure this is a heating issue because even when idle the temperature is at 76C, which seems really high.
So, is there anything I can do to try to fix the problem? Is there any particular areas I can look for on the physical card, maybe some kind of connection between the electronics and the cooling system? Worth taking into a shop?
Thanks
Thanks
