Radeon HD 2950XT Card Pics
Is it safe to assume that a card with one 6pin connector wont be as power hungry, therefore, as fast as the 2900pro/xt?
huh... I thought the XT was suppose to be two GPUs on one PCB, while the Pro was suppose to be just 1.
According to the Inq (yeah, I know, but since we are speculating anyway) it will be faster and use much less power - 4 RV670s will draw less power than 2 R600s, and be more powerful. And they need to be - R600 was a total flop, and everyone knows it. With RV670 using less power, and being more powerful, we are finally going to get a battle royale with NVidia. With NVidia axing the 320MB 8800 GTS, and tweaking the 8800 640MB, they might be set to price themselves right out of the running.
I certainly wouldn't buy a tweaked 8800 GTS 640MB (year old technology) for the current price of $400, and I'm guessing many others won't either unless they absolutely have to get a new card. NVidia made a fortune off of the 8800 series, but if they keep pushing the same exact thing at the same exact price + a tweak or two, it is going to get stale.
ATI stands to be in a competitive position with the RV670, I think, simply because the pricing will be good and performance should be as well. I'm a bit tired of NVidia milking the 8800 technology, even though it is a great product. The prices need to come down.
The cooler looks like the 2600/2900 reference models, but with a hedgehog extension covering the mosfet area, reminds me of the Nvidia 7900 series in layout. I'm giving serious thought to picking this up if I can get it running on a 400w PSU with 30 amps on the +12v's (I skimped on the PSU when building a new computer, unemployed at the time, running a 65w A65 X2)
(edit) Iirc, it's PCIe 2.0 and only needs the 6pin plug in non-PCIe 2.0 machines, the forum link in the OP no longer loads for me
I think that's the 2950pro (not xt). Some of the capacitors on the pcb are in a slightly different position when compared to the first pic
Couple things i like about that pick
1) obviously the single 6-ping
2) less cluttered card, i hate it when cards has a shit ton of capacitors on it and just generally overal cluttered
3) the die is SMALL
It looks as if ATI could shrink the actual card length which would be just as awsome, it looks good over all, if they could get AA performance up with this then this card is definetly a winner.
Yes I know that AA performance most likely wasn't even touched, how ever for a die shrink this card seems to be soaking up all the pluses.
