Integrated HD audio controller
Output protected high bit rate 7.1 channel surround sound over HDMI with no additional cables required
Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
Most newer Nvidia cards from the 210 up have built-in audio. Many of the 4xx series bitstream HD audio, just like the ATI cards do. The 430 and 440 are very popular HTPC cards for this reason.NVIDIA uses a passthrough since you need to connect the wire from soundcard/motherboard onboard to the videocard.... ATI has a built in chip since the 2900 series. Recently with 7.1 support.
Unless I'm wrong
+1 to What Dust said. To clear things:
It doesn't matter if GPU "audio chip" allows to send original bitstream or forces it to be decoded to multichannel PCM - result is the same. The only difference would if you'd have fancy logo light on the receiver.
Ah OK. That makes sense. Howbout optical from sound card to receiver? Same definition as videocards with HDMI?
How do I plug my 3.5mm Sennheisers into my HD6850?
What products do you recommend?You can't. You would need a DAC, to get you an analog output, and then an amplifier. You could use the headphone output on a reciever, although that is basically overkill.
