radeon 9800 pro
caje005
I just bought the Radeon 9800 PRO (works like a dream by the way) and it comes with a DVI - VGA adaptor. I was just wordering if i should hook up my monitor to that instead of the regular vga port. Is there a difference?
THANKS
If your monitor only has a VGA connector, your not going to see a difference by using the DVI adapter. If anything it will be lower in quality because of the conversion.
