Well, I am just learning how to solder, and I plan on doing a 9800 pro Vgpu and Vmem volt mods. I am practicing solderon an old modem, and trying to find little spots that look like similar to what I will have to solder onto my 9800 pro.
I have a couple questions.
1) When practicing with the modem, sometimes the solder will come off the conenction point. I will push it back on with the tip of the iron, but now the PCB is tainted a darker color. If this were to happen, would my 9800 pro be fried?
2) I am using 24 guage speaker wire. Will this stuff work for the connections?
3) I am trying to decide what to do, on some volt mod guides, I see they have a wires taht have a little grabber on the end. Where can I get this because I am scared to death of messing up the soldering on the chip pins.
5) Do you have any techniques I can practice so that the success of my vmods will be increased?
4) Do any of the questions I have asked send a red flag out to you? If so, what have I asked that seems like a big nono.
My soldering iron is a 15 watt radio shack basic.
Thanks in advanced!
Thanks in advanced!
