Originally posted by lurker-drop
3? my goodness![]()
didn't you learn your lesson after the 2nd death?
You don't really want any device that can have high draw in bursts on the same power cable as a hard drive.Originally posted by eli
is it just video cards that cause this problem? can you hook two hard drives up on the same line?
all the 3v 5v and 12v hots are coming from the same switching power supply - they are generated from the same coils... so whlie i agree that its not good to have high draw equipment on the same phyical daisy chain whip (possible voltage drops, surges, etc), isnt all the hots connected anyway? what i mean is, each daisy chain whip isnt a DEDICATED 5v, 12v etc feed from the power supply, they're all tied into the same coil, aren't they? or is the problem the raw amperage when you're at these voltages, when too many amps are on one whip, there is more resistance in the line and starts heating up / burning out the drives / devices internally?Originally posted by 0ldman
Its not good.
May not hurt a CDROM, they're not used as much, but it would probably still be a risk.
Its not good.
