I'm looking at replacing the stock fan on my ATI Radeon 9600pro AIW. I want to replace it to improve both cooling and noise. The tricky thing is that I'm putting it into a Shuttle SFF case and I can't block up the PCI slot (the only other slot I have). Does anyone make something that would fit my needs? I'd like something that would mount in the same holes as my stock fan because I don't trust myself to make new holes in the PCB
I've looked at those VGA cooling solutions but it looks like they take up a PCI slot so unfortunately I can't use it.
Sposh
Sposh
