Radeon 9600 Pro overclocking...
eraser_16
i'm overclocking my 9600 Pro and i'm wondering... would increasing the AGP voltage from 1.5 to 1.6/1.7 help me get higher clock rates on the core and the memory? also, would it be safe?
afaik, increasing the agp voltage *could* allow you to run the agp bus at a higher speed, which in theory, could improve performance, but I don't know what kind of stress etc that puts on the card, so I can't recommend doing it(unless I see that it's not very stressful on the card)
You're probably thinking that increasing the agp voltage would increase the voltage to your core/memory on your video card, which it wouldn't AFAIK, but you can perform volt-mods on it. Search for "unoid 9600" on google.
http://unoid.net/9600pro/
me to the rescue.
you alrdy got a good OC, 500/350+ is always great.
a gpu vmod you could take yourcore up to 1.35ish volts = 540ish mhz gpu.
mem won't gain any really from a vmem.
