I've had a Powercolor R9500np w/ 128MB Hynix mem (W1z softmodded) for a while now and finally got around to doing the VDD and VREF mods for the mem. But my mem OC has been totally inconsistent. Before the mod, I could do 311MHz with default voltages (VDD = 2.82, VREF = 1.24). After-mod, 315 is about all the mem will do consistently w/out artifacts. This is with 2.9 VDD and 1.26 VREF because raising them does not help (and they are the lowest I can go anyway because the VRs won't allow anything lower). But what is strange is that sometimes 330Mhz will also be obtainable at these low voltages. The catch is that it will only be workable (artifact-free) for a couple of boots (ie after that third reboot or so, 330MHz causes major artifacting and I am forced to go back down to 315). Again, Increasing VDD or VREF does not help. If I could somehow get the 330MHz OC to "stick", I would be very satisfied.
The GPU does 420 @ 1.725 and behaves as expected (ie increasing VGPU enables a higher GPU OC). But the mem is totally unpredictable and inconsistent. I know the R9500 is pretty much obsolete considering all the new cards out, but I'm not planning to upgrade until HL2 is out and want to maximize what I got to the fullest. So what is the cause for this bitchy mem? Has anyone else had the same mem OC frustration with this card?
Edit: VGA Silencer rev3 and fully memsinked.
