Radeon 9000 pro and TV problem
daphatgrant
Fi-yah!
Hello, my friend has a SAPPHIRE RADEON 9000 ATLANTIS PRO in his rig, it works perfectly fine until he trys to hook it up to his TV. He has a 32 inch Sharp which connected by an S-Video cable. The problem he is having is whenever he goes to display properties and sets it so the TV is on, it only stays on for 2 or 3 minutes then kicks off. The sleep timer on the TV is turned off. He is using input 1 for the output to the TV.
Anybody have any suggestions? I am lost
Thanks for any help :D
*he is using WinXP, Abit KD7-E, XP2500 Barton, and has the latest v-card drivers*
Just tried uninstalling all the v-card drivers, after a fresh install still no luck!?!?!?! WTF!!!
I dont know, I think its a sign to upgrade, its easy to spend $ when its not mine :p
