Recently installed my 5770. I'm getting very poor quality playing music anytime there's resampling done. I have to set the shared audio mode to 44.1 Khz and 16 bit then my music sounds good. If this is set to 96KHz / 24 bit, it sounds noticibly worse. Tone is changed, loss of base and less "soundstage." This is unacceptable as even a crappy resampling algorithm should be nearly transparent, especially for upsampling!!!
I have some 96 KHz / 24 bit and 96 KHz / 32 bit output (lossy) tracks, and these also sound different when changing 44.1 --> 96. 44.1 still sounds better and I get nearly the same effect when changing to 96 KHz, but it does seem these sound better at 96 then the 44.1 khz tracks sampled to 96.
Performance Summary:
I get the same effect on playback / shared mode at 192 KHz. Sounds like 96 KHz.
The card I replaced...my Creative X-Fi Fatality professional resampled *anything* to *anything* and it would always sound completely transparent. I could never tell the difference between 44.1, 48, 92, 192 khz from any source, be it 44.1, 48 or 96 khz. Same as between 16 & 24 bit.
This is unacceptable because this is a media centered PC, I have music at 44.1, 48 and 96 Khz. I have movies with audio tracks ranging from 44.1 khz MP3 to 96 KHz AAC to DTS tracks to TrueHD/DTS-HD lossless tracks. I cant keep switching the output format around for each movie / song I play.
Any ideas? I havent found any reports on the web similar to mine, and it seems like somthing like the would be more reported. This leads me to think that my card may be defective.... Could it be drivers...? I wonder if I should do a clean install with the X-Fi card removed from the PCI slot.
- 44.1 khz music sounds great when played back in shared mode set to 44.1 / 16
- 44.1 khz music suddenly sounds weak, tone changed and loss of bass when played in 96 khz shared mode (16 or 24 bit) Very significant change, and even a crappy resampling algorithm should not sound like this!
- 96/24 music played back at 44.1 khz sounds fine.
- 96/24 music sounds OK when played back at 96, but doesnt sound "right" Sounds better at 44.1
- switching between 16 bit and 24 bit on shared mode makes a noticible difference in audio,. Should be pretty much transparent, especially on the tracks I'm playing... even if truncated.
