Radeon 3870 X2 - Noob Question..
The easiest way to make sure they are both running is to run 3dMark06 and check your fps. There is no reason for one of the gpu's to not be running. The crossfire is internal and can't be disabled, unless you have Catalyst AI turned off in the CCC.
I would suggest grabbing a copy of RivaTuner and monitor your clock speeds while you are gaming, to make sure you don't have the PowerPlay bug. We have a thread in the ATI forums about it with a ton of info.
You can open up CCC and look at the GPU utilization on both cores in Overdrive. If you have dual monitors set CCC on the second display while you are playing your game, and have the second GPU selected, and watch the GPU utilization monitor.
Screenshot of it here - http://hardocp.com/image.html?image=MTIwNDY2NDkzOFVjZ0JlSzFEYkpfM18yX2wuanBn
Note that you need the 8-pin power connector plugged in for Overdrive to show up.
