Rade 0 striping:problems with counterstrike
Bushnuts
Ok i recently redid my Computer with raid 0 striping config.. ever since ive had a problem with counterstrike. Every like 20 sec it will pause for a split second liike a glitch.. Apears to b a video problem but i get 100 fps at all times and i have 20 ping. and when i redid my hard drives I didnt change the video card or anythin.. only thing i really changed wus added a raid controller and set it up in raid config... can anyone help??
patience is a virtue padawan. you will soon learn the ways of the [H]
Talonz said:
Do you happen to need drivers for your raid config?
if you're using an intel board try installing the application accelerator raid edition.
The question is, why are you in Raid0 at all? Just to say that you are? b/c as far as I can tell, it just doubles your risk of data loss, without any noticable performance gain..
Hrm ill try that Mrwoot ty.... and for Woofer00 raid 0 does up ur performance.. but not in gaming... how long does it normally take u to install windows?? took me 20 mins
It took me 30 minutes or so to slipstream sp2. Let me ask you this - how long does it take you to boot? I reformatted to remove RAID b/c it took longer to boot for no noticable gain unless i was encoding/ripping video, something I rarely ever do. Now I never see a raid controller startup screen, and I don't see any real performance hits. I don't trust HD's for my data, RAID 5 or 0+1 for me if I did it at all, which I wont.
http://www.hardforum.com/showthread.php?t=826894
