Ok, so my loop is all put together, using 7/16 tubing over 1/2 barbs and using worm clamps, just to be safe. Everything was fine until I noticed some leaking from the rad. Oh brother.
I've got a 77 Bonneville core that has worked flawlessly for a year and a half. I am in the process of upgrading my rig with a Storm block, a new Maze4, and an AMD setup. Have the rad on the bottom of my Stacker case. I noticed some leaking, not from a loose worm clamp, but from the base of where the threaded end of the 1/2 barb screws into the rad. I bought this a while back and the threads appear to have had some black substance on them presumably to prevent leaks. Maybe this side wore out? Maybe I overtorqued it getting the old tubing off??? I dont know. But that bard won't budge so I know its on tight.
Can anyone recommend something I can buy to stop that leak dead in its tracks??? This upgrade has been amost 6 months in the making, setback after setback and here's yet ANOTHER damn setback. Any suggestions? I really don't want to take this loop apart so I hope there is some way I can stop this. This is very discouraging. My first watercooling setup 2 1/2 years ago had no leaks. The watercooling setup I've used for the last year and a half (including this rad) I have had zero leaks. There's gotta be something I can slap on that to stop it from leaking. Suggestions welcome.
Thanks
Thanks
