Rad for an Antec Super Lan Boy?
AtomicFire
I'm doing a simple wc setup for my main rig in my quest for 4Ghz. I need a rad that will fit in the back 120mm inside of the case. Any Suggestions? There ia maybe a 1 inch space between the fan mounts and the bottom of the power supply and the rad will be mounted inside the case
CoolRad -12T
It outperforms the BIX in testing and costs less
awesome thanks! i'm checking it out now, before I was considering just getting the BIP and taking a gamble as to how it would fit. :p thanks!
Edit:
just ordered one from SVC. Tons cheaper than the BIX or BIP and includes a shroud and two different sized fittings...sounds like a win-win deal to me :p
