Racoon configuration
runt
I currently have a Linux box at home running as my DHCP/DNS/OpenVPN/IPSec VPN/etc server. The IPSec VPN Server is Racoon, however so far I have only been able to get it to hand out address in the 10.8.1.1-255 subnet when my normal subnet is 172.16.6.1-255. Problem with this I cannot access any other machines on my network (like my servers RAC). How do I configure Racoon to hand out a specific range of IPs, say from 172.16.6.80-89 (not handed out by my DHCP server)?
It could very well be a route I'm missing, but I have no clue what that route should be. I've tried
Code:
route add -net 10.8.1.0 netmask 255.0.0.0 dev eth0
But it still doesn't allow me to access other IPs. I'm guessing its because I don't have a gateway but I don't want to scree it up right now.
Route w/ one client shows the following.
Code:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
10.8.0.2        *               255.255.255.255 UH    0      0        0 tun0
172.16.6.0      *               255.255.255.0   U     0      0        0 br0
10.8.0.0        10.8.0.2        255.255.255.0   UG    0      0        0 tun0
192.168.122.0   *               255.255.255.0   U     0      0        0 virbr0
link-local      *               255.255.0.0     U     1003   0        0 br0
default         h001.mccloud.lo 0.0.0.0         UG    0      0        0 br0
I can add the route from 10.8.1.0 to 172.16.6.0 just fine, but i can't go the other way for some reason.
Code:
[shaun@hda ~]$ sudo route add -net 10.8.1.0 netmask 255.255.255.0 gw 172.16.6.1
[sudo] password for shaun:
[shaun@hda ~]$ sudo route add -net 172.16.6.0 netmask 255.255.255.0 gw 10.8.1.1
SIOCADDRT: No such process
[shaun@hda ~]$ route
10.8.1.0        h001.mccloud.lo 255.255.255.0   UG    0      0        0 br0
Could part of the issue be that Racoon doesn't create a device at all? OpenVPN does but there is nothing for Racoon. Here is my ifconfig output
Code:
br0       Link encap:Ethernet  HWaddr 2C:76:8A:AD:EF:B0
          inet addr:172.16.6.3  Bcast:172.16.6.255  Mask:255.255.255.0
          inet6 addr: fe80::2e76:8aff:fead:efb0/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:31217026 errors:0 dropped:0 overruns:0 frame:0
          TX packets:17230281 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:33558624017 (31.2 GiB)  TX bytes:31590418939 (29.4 GiB)
eth0      Link encap:Ethernet  HWaddr 2C:76:8A:AD:EF:B0
          RX packets:52495080 errors:0 dropped:0 overruns:0 frame:0
          TX packets:47052383 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:65532537016 (61.0 GiB)  TX bytes:33487619345 (31.1 GiB)
          Interrupt:18
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:7182464 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7182464 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:40843678608 (38.0 GiB)  TX bytes:40843678608 (38.0 GiB)
tun0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:10.8.0.1  P-t-P:10.8.0.2  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1338 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 b)  TX bytes:235369 (229.8 KiB)
virbr0    Link encap:Ethernet  HWaddr 3E:DF:E7:ED:90:89
          inet addr:192.168.122.1  Bcast:192.168.122.255  Mask:255.255.255.0
          TX packets:37126 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 b)  TX bytes:5192855 (4.9 MiB)
vnet0     Link encap:Ethernet  HWaddr FE:54:00:0A:64:F6
          inet6 addr: fe80::fc54:ff:fe0a:64f6/64 Scope:Link
          RX packets:10516110 errors:0 dropped:0 overruns:0 frame:0
          TX packets:20856296 errors:0 dropped:0 overruns:91 carrier:0
          collisions:0 txqueuelen:500
          RX bytes:597510604 (569.8 MiB)  TX bytes:31269796401 (29.1 GiB)
br0 is my Linux KVM bridge/main IP for the box, tun0-00 is my OpenVPN tunnel, virbr0 is for NATted Linux KVM VMs & vnet0 is for Linux KVM VMs w/o access to anything else on my network. So far, only br0 is used for a VM (it is only a HP MicroServer N40L so it doesn't have lots of spare CPU time).
