Rackmounted 2600k Build
musicjerm
I just finished my new Sandy Bridge build and thought I'd post some pics and get some feedback.
Specs:
Lian Li PC-C32B Rackmountable Case
Antec Truepower Quattro 1000W Power Supply
ASUS P8P67 Deluxe Motherboard
Intel Core i7 2600k Processor
Corsair 8GB DDR3 1600Mhz Dominator Memory
EVGA GTX 480 Graphics Card (Upgraded for free from a GTX 295 RMA)
Intel X25-M 160GB and 80GB SSDs
Liteon Blu-Ray Rom
Liquid Components Used:
EK HF CPU Block
EK GTX 480 Block
EK Radiators (2 x 240)
Swiftek D5 Pump with EK Top
Koolance Quick Disconnects and Compression Fittings
Tygon 1/2" ID Tubing
Feser UV Blue Fluid (still need to add UV lighting)
This system was built at our Local A to Z Computers here in Riverdale Utah.
Thanks to my co-worker Mike for his help with the window and some minor case/psu mods.
Thanks in advance for all comments!
Also, temps dropped from about 60c to 30c on the cpu and 90c to 50c on the graphics card under a load. CPU is running at 4.8Ghz perfectly stable.
That is a Quiklok RS-514 Rack
I do a bit of Audio recording and will eventually add a nice audio interface, possibly some other rackable things (nas storage/server or something)
thanks im looking to mount a rack case like you and an a/v receiver
