Rackmodding
Hi all, anyone know a good way to make a 5.25 to a 3.5 inch bay in a coolermaster wave master case?
i tried finding a conversion box from Coolermaster, but i couldnt find one, thanks all.
Making a 5.25 to 3.5
Start with equal parts aluminum and acrylic. add 3 tsp Cinnamon. bake at 350F for...
Actually, try frozenCPU or mountainmods both have nice converters. If you are set on making one, get some aluminum sheet from home depot, and some 3/16" X 1" steel. Use the steel with c-clamp, vice-grip, what ever as a metal brake so you can bend straight. You can use the converters on those sites as a guide. That or you could cut / glue acrylic sheet too. all depends on what you want.
