Rackable SE3016 Power Supply
mskurnik
I purchased a SE3016 from ebay last year but I rarely keep it on for more than a few hours as the PSU fan is rather loud. I've seen a few posts on the forums here about modifying the SE3016 power supply but I was wondering if there was a power supply I could purchase that would work with this. I know from this posting that the power supply is replaceable but I am really uncertain if the PSU is really just a standard ATX PSU or if I need something a little different.
Well the PSU that's inside is not at all ATX in its form factor but the idea is that you should be able to use an ATX PSU instead. It would need some work though, so as long as the current PSU works I would just replace the horrible 40mm fans.
