Rack rails for non-rackmount cases
Digital39
Hey all,
I have a couple cases that are built very similar to rackmount cases and I wanted to put them in my home cabinet. Has anyone seen a set of rails or a kit to allow you to take any case and rack mount it? I would prefer not to go with a shelf or replacing the cases
Thanks
I've used rails that are just a small 2" lip on either side, but, they've always seemed a bit unstable IMO
I've seen a set of those, however they were like $120, do you know of a cheaper set? I was considering using a set of those and then screwing a support beam under it between the vertical posts for added security,
Never purchased the sets I've used, so, I can't help you there.
If you're trying to do this on the cheap, 4-post shelves are really your best bet unless you know a metalworker....
thanks I will see what I can find...sorta off topic, but do you have a good resource for cases, I need a couple 2U cases and most are $100+
Checked around on e-bay?
$100 is a reasonable amount for a 2u case. Impossible to find something below $50, and you'd need to add a PSU to ones in that pricerange anyway
