r9 390
Very descriptive, OP. Thanks! Would read again! AA++++++
Don't buy from Directron. Never liked them. B&H is totally legit. I'm holding out for an MSI R390X for (hopefully) a BF deal. Right now I can score it for $368.98 from Newegg.
I see them for 250 at Microcenter long as you are ok with returned items.
I've not had any problem with Directron, but I've only dealt with them once--got my first computer from them; it worked pretty well, but was definitely low-end. lol
Directron is normally on the high end of the prices, nowadays.
You could always scoop up a used 290x on eBay for $100+ cheaper, that's what I did. That extra 4gb doesn't do much for you. Other than that it's the same card
Unless you really care about high textures. BO3 pushes my 390X past 4GB. :cool:
5760*1080 tends to hurt 3/4gb of ram
Let's not kid ourselves and say we are driving that resolution on one 390x. 2 sure but then you are just making my case even easier when you can just crossfire 2x 290x. Even then if you must have 8gb I've seen 8gb 290x for about $250. Personally I picked up a pair of 290x's on eBay for 220$ and they drive my 4k monitor fine. Sure I have to turn aa off but I can't see jaggies anyway.
The point I am trying to make is the 390 and 390x are a bad value when there is such a glut of 290x's on the secondary market.
If you don't mind buying used with no warranty, sure. Go right ahead. When one dies or you have a problem you're out that $220-250 or whatever. GLHF
And I highly doubt you got a pair of 290X's for $220.
Oh, and good luck driving those resolutions with any high settings in recent games. FO4 and BO3 both chew up more than 4GB on my single 2560x1440.
I can run Elite: Dangerous on all high settings 1440p (AA disabled on a 1080p screen), and get min 15fps (during super-cruise, etc.), generally capped to 60fps though, on my single 4GB 270x (while capturing 1080p video to a slow HDD). Granted, it's not the most demanding game ever, but that's still not bad. ARK runs fine too, shaders maxed and AA disabled.
I don't know much about resource usage in FO4 or BO3, but I don't imagine myself playing either on High with my current card anyway. Will definitely upgrade before getting either, probably to one of AMD's upcoming HBM cards.
when will people learn how vram allocation works? you can get games to use over 8 GB on a Titan X, does that mean you're going to get stuttering on a 4 or 6 GB card? no, it means that the engine is putting shit in vram because it can. i play both FO4 and BO3 at 1440p and get absolutely ZERO stuttering with a 970. the 390 and 390X are gimmick cards at best designed to target the "ooh big number" crowd, when in reality they have absolutely no reason to have that much vram other than so they can resell 290s and 290Xs under a different name for more money. same story as 3 GB GTX 580s or 6 GB GTX 780s.
You are absolutely correct about the warranty. However, many sellers are willing to give you the original receipt if you ask them, it also can be a bargaining chip when you are making a best offer. You are taking a calculated risk of course but if it is not DOA(to which eBay has wonderful protection policies in place for) chances are it's going to be fine till your next upgrade cycle. In response to the resolution comment, games like dying light, vermintide, and dragon age inquisition run great at 4k, I don't play call of duty so I can't give you a comparison and fo4 doesnt have an sli or crossfire profile yet. Just because they don't have 8gb doesn't mean that the two cards can't muscle past that limitation. That argument will be moot when dx12 comes out and memory is shared as well. Finally, you aren't scoring any points by calling me a liar on what I got them for, all I can tell you is you need to be patient. The deals are there they just don't last long. Again, I will reiterate that the only point I am trying to make is that the 390 and 390x are bad values because they are just rebadged 290s with 0-4 more GB of vram and there is still tons of 290s for sale if you know where to look.
