get the same problem with only 1 gpu ?
u should take time to make yourself a forum signature so ppl will know what your general system is.
Powersupply , mobo what not.
are u using the default cooler or water cooling? quiet or uber mode?
in catalyst controler , under amd overdrive, is your gpu target temp still at 95c?
Try a run of 3DMark 11 and see if your scores are in line. If so, the graphing in Afterburner is wak. If not you're card is really throttling. Looking at that graph though it doesn't show it throttling, it shows it coming to a complete halt for seconds at a time.
Well, I got decent results.
What killed my score in comparison to his was that my max CPU clock was 3.7ghz, while his was 4.4ghz.
So, that being said I'm thinking that it's just Afterburner being completely and utterly wrong. Additionally, it seems like it might just be Batman having problems.
was this a crossfire score. This seems low if it was
Hmm. Im in the 19k with my 680 sli. I figured 290x xfire would be way ahead.
You have a 3930k@4.8ghz, that's why you're so far ahead of me.
Still, this issue is bothering me. Anybody else with a 290X CF setup confirm the weird readings?
I'm getting weird reading too. My score is a little higher than yours with my 3570k @ 4.4 and stock bios on my two 290x.![]()
i doubt my my over clock. would make up that huge diff over 290x crossfire.
here is my score. with one 290x. something is wrong with your score.
http://www.3dmark.com/3dm11/7424934
try gpuz, see what it says...
Yeah, sorry, i posted before i read the 2nd page.
i would guess AB needs to be updated for the 290 series, and is reading incorrectly.
You could also try Aida64 and see what it says,.
