- Aug 4, 2004
Anyone familiar with the the differences between V1 and V2 of the Dell R710 servers? I've got 2 V2 servers and 1 v1 server that I would like to make use of. I've looked all over but the only differences I can find appear to be CPU support (v2 support 130W CPUs).
What I'm running into is that the v1 server system fans are running about 1000 RPM higher than the v2 servers under the same load. Swapping fans doesn't make a difference. I've swapped out the memory modules also, just to compare. The v2's are running X5650 procs vs the v1 server which has a single X5550 which is the only difference other than the motherboard.
Any ideas if this is just a difference between the motherboard versions? Possibly the CPU model? Or do the system fans run faster with only 1 CPU vs. 2?
I could get a replacement motherboard (v2) or replace the CPU (with an Intel L5640 perferrably), but don't feel like spending the money if that's not going to drop the RPMs. I guess I could pull a CPU from one of the Gen2's temporarily to test and see if it is the CPU model.. but that doesn't rule out the dual CPU configuration (unless I pull both).
