R7 250 not installing correct drivers
zalazin
I uninstalled the hd 5450 using ddu uninstaller. Down loaded the newest Beta hotfix drivers,disabled antivirus. When I installed the driver It boots into win 7 64 bit fine, After I log on the screen goes to black saying unsupported mode. I booted into safe mode changed resolution even down to 800 by 600. Still have same issue. Uninstalled again went to AMD used their auto check utlity and It Tells me I have an HD8000 OEM WTF!! I went into Bios configured Graphics to GFX0-GPP-IGFX-PCI as I have read. I have never had this happen before. I used DDU to uninstall all amd and any scrap of Nvidia. I didn't want to use the old HD5450 Radeon driver. WTF is going on here? PS Amd still says I have HD8000
Spec AMD T-1055 Hex core, 880g based Motherboard, 8GB ddr3, Renesssas PCi1x usb 3 card. 1 intel 80 GB sata2 ssd boot drive 5 Seagate 3TB drives Thermtake SP850 PSU Corsair H60 water cooler. Win 7 64 bit MSI R7-250 VC
Also This is a 37 insignia TV from best buy. But it Never had any issues before with 3 different cards used. the monitor is an NS-37L760A12
TRied he drivers no go. But I switched to Vga ouput and tv works perfectly. I don't really remember If I used the hdmi before I thought it worked but now I' not sure.
Thanks for the help. Who would have thought a basic Video card upgrade would be a RatF%^%K...
you would think the hdmi would work! lol may just be a question of what the tv likes
It was the monitor put the R7 in another machine different monitor Hdmi worked perfectly. Cheap ass Bestbuy product....
