Ouline: Have a week off work, going to push my stable OC, starting very perliminary, then slowly tighten tweek for max output.
Hardware:
Qx6700es
Asus P5W DH Deluxe
Coolit Freezone Modified: 114cfm 120mm fan, duct tape fan shroud, removed aluminum side plates, "control" set to high
Noctura NH-U6 fanless chipset cooler on the NB with AS5
Stock southbridge heatsink (shiny asus tin cover removed, AS5 to be applied soon)
4GB Team Xtreme DDR2 800 4-4-4-10@2.0-2.2 naked w/OCZ mem cooler
Ati AIW x1900
OCZ 600w Evostream PSU
74Gb Raptor sata
250GB WD sata
Case:
Coolermaster 830 silver
3x 45cfm 120mm front intake fans (plus 1 62cfm 140mm fan (at the back of the empty drive bays much closer the the mb, verticaly in the middle of the 9 5.25 bays)
1x 45cfm 120mm top exhaust
2x 62cfm 140mm side intake (swivel fan door) blowing at the bottom of the mb/AIW)
1x 62cfm 140mm side exhaust (swivel fan door) located right above the OCZ mem cooler blowing in the same direction
OCZ P/S with 2x80mm fans, 1 sucking from the void above the mb, one exhaust out the case)
*actually low db fans except for on the freezone, thats an airplane.
Software:
Asus 1707 Bios
Intel's TAT
Orthos beta (for C2d, running 2 instances, affinity's set core 0/1}aff1 2/3}aff2
Xp Pro SP2
Room setup:
This 14'x10' room has very poor ventilation, 28GHz including this folding, and a high ambient air temperature, therefore until I settle on a stable OC I'm trying to run this with the window open (Canadian Winter) hallway door shut (keep rest of the house warm) I have a old occilating fan under the window (nw corner), a wall clock with temp 3ft east of the window on the north wall. NE corner of the room houses a D805 @3.2G and my T7600 dell M2010 "laptop". Sw corner has my old P4 2.4 laptop, a Via 1Ghz, and a P4 3.4. I'm in the Se corner near the hallway door (closed) and have a temp readout on my Logitech keyboard. (simply put, cold air supply and me are in opposite corners of the room, with folding machines in the other 2 corners) All machines are on and folding (cept this while I tweak) I typed all that out so you can understand why I'm doing this with the window open, dont pay too much attention to the idel/load temps because unless you compute outside they're on the cool side, I'm mostly interested in what the chip will do at certain voltages/FSB/Multi's right now and will be watching the temp changes (delta's)
I dont know if there will be much interest in this, for a while at least this week I'll try to update this thread, feel free to bookmark it
Here are some pics I put in another thread, apologies for the shaky hand.
Hardware:
Qx6700es
Asus P5W DH Deluxe
Ati AIW x1900
74Gb Raptor sata
250GB WD sata
Case:
Software:
Asus 1707 Bios
Intel's TAT
Xp Pro SP2
Room setup:
