Haste266 said:they dont have any quad core processor listed as available.
They seem to have OEM's in again now.
Compared to my X2 4800? Definitely. 50% better performance per core, and two more of them to boot, it's great. Paint.NET's performance scales incredibly with more cores.savantu said:Are you satisfied with it ? That's the question!
rolo said:Compared to my X2 4800? Definitely. 50% better performance per core, and two more of them to boot, it's great. Paint.NET's performance scales incredibly with more cores.
I couldn't get it to go at 3.46ghz, at up to 1.45v. I didn't try any higher. It failed Prime95 x4 after about 5 seconds at that setting. (I'm running the 64-bit Prime95 btw )
rolo said:Yeah I'm not sure if the cooler I got is very good. I got this one: http://www.newegg.com/product/product.asp?item=N82E16835103001 . I used arctic silver instead of what came with it.
I figured I'd rather get the OEM and save $500, rather than pay $500 for a Intel stock HSF and a sweet "Intel Inside" case sticker.
rolo said:Got mine all set up ... it's great! 3.2ghz right away
chrisf6969 said:you get a $1000 processor why not pony up $50 for a good cooler.
see here for some good coolers: http://www.hardforum.com/showthread.php?t=1123593
Tuniq tower (not in stock anywhere?), Scythe Infinity, Thermalright Ultra 120, etc.. are on the top of the list.
Very nice! What voltage, etc.? Which HSF?LOCO LAPTOP said:3.6Ghz didnt try to overclock it more yet.
chrisf6969 said:I think the Thermalright Ultra 120 is a good combo of cooling with a 120mm fan, but not outrageously big like the Tuniq tower or Scythe Infinity.
Off topic: but the rumor mill
is saying the
Q6400 will be $600
Q6600 will be $800
QX6700 is $1000 (we already know)
matches up to the FX-7_ pricing, but more than I was expecting for the Q6400.
Oh well
savantu said:Q6300 ~ $423
Q6400 $599
Q6600 $851
Q6400 $599
Q6600 $851
is saying the
Q6400 will be $600
Q6600 will be $800
Oh well
Take off the heat spreader? Oh heck no, not me. Last time I tried that I ruined a S754 A64 2800+. Luckily that was only a $150 mistakeswetmore said:So who is going to be the first to crack the lid and show us the pics?
rolo said:Very nice! What voltage, etc.? Which HSF?
Are we going to be having the QX6700 added to the overclocking database thread?
JethroXP said:I figured while I'm taking pictures, I might as well show all the parts I've got for this new system.
Motherboard: Gigabyte GA-965P-DQ6
CPU: Intel Core 2 Extreme QX6700
Video Card: XFX 8800GTX
RAM: Corsair XMS Pro Twin2X 2048-6400
HDD: 2x WD SE16 500GB SATAII
DVD: NEC 7170 DVD+/R/RW/DL/DVD-RAM
Heatsink: Thermaltake Blue Orb II
Just waiting on the case (Lian-Li PC7 Plus II) and power supply (Thermaltake 750W Toughpower) which should be here Thursday.
http://jethroxp.shackspace.com/forum/QX6700-AllParts.jpg[/QUOTE]
Thats sad.. All that stuff, with a crappy heatsink, a crappy power supply, and only 2 gigs of ram..
Otherwise, looking nice.. Not a big fan of gigabyte mobo's though..
JethroXP said:Oh? And what would your suggestions be?
I see from your sig that you have a Zalman CNPS 9500. I considered one of those, but after looking through many Heatsink reviews that included head-to-head comparisons of the CNPS 9500 to the Blue Orb II, I found that the Blue Orb came out cooler and quieter in every test.
I also found that the Toughpower 750W PS has done very well in reviews too, so I'm not sure where your description of "crappy" is coming from.
As for only 2GB of RAM, that's what I currently use in my existing main system and I've never had issues. Once I load Vista on this new machine if I find that 2GB isn't adequate I'll still have two avaialable DIMM Slots to add another 2GB if needed.
Well dang man, you got a very nice chip then! Mine won't even post at 3.73, let alone 3.46 with much higher voltage. I'm at 1.425v right now, 3.2ghz.LOCO LAPTOP said:now im at 3.8Ghz at 1.5V on watercooling
Astrogiblet said:Personally I dont like the 9500 either. Nor the blue orb, nor anything with this kind of design. I would recommend going with something like the Scythe infinity, or Tuniq Tower, as for 4 cores you will need maximum possible cooling. The blue orb is smashed down like that because its designed for use in small form factor cases and home theater computers....
2gb's of RAM. You have 4 processors, each one of those 4 processors needs some amount of RAM in order to feed information to it. I wouldnt recommend running less than 2gb's of RAM on a single core, let alone 4 cores. My minimum recommendation for you is as much as you can get. 4GB's would be optimal, if, of course, XP properly used that much. If you are using XP x64 then 4gb's would work, or linux, or vista, etc..
Thermaltake power supplies.. I've heard nothing but bad things about them.. I prefer, personally, to stick with antec, enermax, pc p&c, etc.. Bigger named companies.. And 750w seems a bit little to be running a quad core, 2 500gb hard drives, and an 8800gtx.. It will probably work, but it just seems so tiny..
Astrogiblet said:Well you seem a lot more informed on what your buying then I thought. Although I dont agree with some of the things you've said, you sound like you know what your doing.
JethroXP said:Having watched Newegg very closely for the past two months, I've noticed minor price fluctuations on many of their products, but generally never more than a few dollars per week. The price swings with the QX6700 have been crazy, from $1199 up to $1699, sometimes within a day or two. I'd be curious to know what drives that, other than pure supply and demand.
