ohboring1 said:I want to build a very very quite system around an AMD Athlon 64 X2 4200+... any suggestions?.. oh yes.. i'd like to be air cooled too.. I don't want to bother with water cooling.
Haha, brilliant!Hallow said:I don't quiet understand what you're asking.![]()
Mayhs said:i think he meant quiet![]()
spine said:Haha, brilliant!
But yeah, xp120 with a low flow 120mm fan. I have to disagree with the above poster about panaflo fans; they are particularly noisy even at the lowest of speeds due to their ball bearings rumbling. I own 2 of them and both are equally as bad.
I'd recommend any cheap ball bearingless 120mm fan with an rpm of 1500 tops and run it at lower volts as required.
In my experience, dirt cheap fans tend to be quieter than expensive ball bearing fans.
Burner27 said:I know. Hence the reason for my smilies after what I wrote.....![]()
