Quincunx AA or 2xAA?
godzboyz
If I use QuincunxAA with -.9 Mipmapping the image is slightly distorted but more alaised and it is also slightly more blurry,
[/URL][/IMG] IF I use 2xAA with -.3 mipmapping the images are less blurry and less distorted due to lower neg mipmapping but straightlines are more alaised, but the hellknight still remains the same...
[/URL][/IMG] Any suggestions?... They both have almost the same performance.
Quincunx is more or less equivalent to 5xAA.
But because it's a bit hacked to get it fast, it does get a bit blurry. Still better than 2xAA if you ask me.
Why do you change both the mipmap bias and the AA method though at the same time though? That makes it way harder to figure out which setting does what.
I have to use at least -.8 mipmaping when QUINCUNX is enabled otherwise the image is so blurry I can't see detailed textures at all since I have a big moniter...
Doom3 screenshots are always darker than usual I already enhanced it's brightness by 33 via a program I'm not sure about the contrast.... you should see the ones on gamespot LOL they're insanely dark
