Quietest Fans w/ good performance???
chew63
I'm looking for some quiet 120mm fans to replace the stock fans on my case. What fans give the best performance/noise ratio?
thanks for the help...
silent.... panaflo yes, but uber silent =
silenx fans
e.g. 120mm fan, 58cfm 14db. i.e. you cannot hear them.
what's the benefit of the "7volt mod" and where could I find out how to do it?
TT always gives their products very flattering specifications that they never live up to.
SilenX makes excellent quiet fans, as does Vantec and Sanyo Denki,.
Thermaltake overrates their cfm ratings and underrate their dBA values. SilenX fans are just too expensive. I like the Panaflos.
chew63 said:
I've heard they exaggerate their statistics and places like www.silentpcreview.com don't review them because of this...
I own several SilenX fans and although I cannot by ear or feel tell 58cfm from 50cfm or14db from 19db, I find them to be really quiet performers. Panaflows are nice, but you won't be disappointed with these.
One word of caution, silencing your computer can spiral into an expensive, ongoing process. I first replaced the loud, high-pitched graphics card stock fan. Then the case fans sounded loud. I replaced those and then the CPU fan noise stuck out. Switched that out and now the sound of HDD drives spinning is more than I want to hear...oh and I forgot to mention swapping out the PSU fans as well.
I ordered some Panaflos and some rubber fan silencers, and rubber grommets to go with them, hopefully that will help the noise level some.
I can see how it would. The ATI silencer I have isn't too loud, and neither is the cnps7000 cpu cooler. The main thing after the case fans for me is the HD's. thanks for the suggestions everybody.
I have a pair of Yate Loon 120mm fans that move a good ammount of air and are quieter than the Panaflo L1A's they replaced.
Got em HERE.
