Quietest Computer possible
Pdwe
Case: 4 bay
Fans: 120 mm (Nexus)
Power Supply 750-850 Watt range
Sata Dvd Rw
Budget: 3,000
I'd love to have an idea on what case and power supply to look into.
Check out silentpcreview.com
I'd probably suggest either an Antec Solo (or Antec NSK equivalent) or the P180B (or P180, P182, P182SE, etc).
For a PSU, any Seasonic, or Seasonic-made Corsair would be good (HX520, HX620, VX450, etc).
For HDD, Samsung F1 series, WD3200AAKS, or WD6400AAKS. Samsung SH-S203B or S203N for the DVDRW drive.
Noctua and SilenX fans are also quiet, along with Scythe S-Flex.
As for CPU HSF, either of these would be good...:
$59 - Noctua NH-U12P Universal heatsink
$57 - Thermalright Ultra 120 eXtreme CPU HS + Scythe S-Flex Fan SFF21E ($15)
Though, the loudest part of a gaming system is most likely the Vidcard (GPU HSF). So, is this a gaming system? If not, you can get a fanless low end card. If it is a gaming system, look for something with a heatpipe, dual slot cooler, if you can't find a fanless (passive heatsink) vidcard.
