Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
What are some of the quietest cases out there? I'm looking for $50-$120, in price range.. I'm looking for something that has good sound proofing / padding possibly and big low speed fans that move lots of air. What's in this arena?
the haf series are mostly like that. also i think the rv02 is supposed to be pretty quiet, it would be at the end of the price range you are looking. i have a haf 922 and its pretty quiet and it moves good air. if you need a full size, then a haf 932 black edition would be a nice choice too imo.
Dang buggers are expensive. I used to buy pc cases for $30 - $50... What's the big difference between the cheapies and the expensive ones? Just better sound reduction and airflow and build quality?
What you mentioned aren't necessarily things you can put the word "just" in front of. Those are all a big deal when it comes to cases. Also, more expensive cases will generally have more options for usability like different hard drive rack configurations, better cable management, better tool-less features, etc. If you spend the money on a better case, you WILL notice the difference. Also, regarding your price range and wanted features, you probably won't find anything that has sound padding in it as a stock feature. Generally sound padding commands a price premium.
