quietest 600w PSU under load
Sem
Hi
whats the quietest 600w psu you can get under load
i tried a seasonic M12 but under load the thing is bloody loud :mad:
The M12 has the 60mm fan.
Try the S12. What are you trying to power? I can assure you that unless it's like octel quad sli with 48 cpu's and a 128 disk array of 23k scsi's, you won't be drawing 600w.
Other alternatives: S12-EP 650, Corsair HX 620
my system is a E6600 @ 3.6 8800GTS 4xHDDs 2xOptical drives
I am kind of in the same boat. I like the S12-600 personally, but read that there were reliability issues. I plan on running a single mid-range card. I was hoping for a PSU that would handle a complete upgrade even 2-3 years in the future.
Enermax 600 noisetaker, the thing is inaudible and I mean that, I have 3 and I cant hear a fuxing thing coming from them when the pc's are on, I hear all the other fans and even the harddrives before I would ever hear the psu making a noise, thats how quiet they are.
If I never had any main fans ( intake/exhaust/cpu) at all in my pc, I would hear the harddrives and then the chipset fan then vid card and phyics card fans way before I would hear the psu.
uber quiet.
Silent PC Review recently updated their list of PSUs. Might be a good "short list" to use for selecting one.
SPCR
So far I really like my XClio 600W. (just got it recently)
It has a 140mm fan and specs that beat everything else in its price range (efficiency, amps, etc)!! 4 PCIe connectors (for SLI 8800's)
My whole system is so quiet I had to put the harddrive in a "silencer" enclosure.
My FSP FX600-GLN is dead silent ... MUCH quieter than previous PSUs (Ultra V-Series 500w and Sunbeamtech NUUO 550w).
Seasonic m12 600, i cant hear it one inch away (granted, it doesnt seem to push an air either, but its been dead stable)
Bbq said:
If you don't plan on upgrading to SLI, then this will be perfect. Alternative
I got the 550w version and it's dead silent even when it ramps up the fan speed when needed. It's rock solid on the rails as well. The only thing I can hear in my case at this point is my 74GB Raptor.
me too thats why I bought the harddrive silencer enclosure! :)
Thats odd.... I got the Xclio 650W and its actually kind of loud when it ramps up! Maybe I got screwed ?
Hmmmm
