quietening a Zippy?
eer
I have a Zippy 700w, thing works great but is just way to loud. I ordered a 120mm Panaflo M1A fan and a 80mm to 120mm converter to replace the stock fan. Do you guys think this is a good idea? And if i do it should I put a temp sensor on the heat sink in the psu?
Hope this works. only other option is to water cool it.
Thanks,
Ken
guys at xtreme systems slapped a stock AMD opteron fan in there. I's silent at low speed, and has a temp thermisistor to ramp it up when the psu gets hot.
Ah, just saw it. might try it since i have one of those around somewhere. The stock zippy fan only pushes 55cfm the 120mm that i bought pushes 80cfm so all will be good.
Thanks for the post. ;)
