Quiet Socket A HSF
dchrsf
What would you guys recommend for a good near silent socket a hs/f combo that would run on a Abit NF7-S v 2.0 without hitting caps etc? I am trying to keep the cost below 50bucks..This will be cooling a 3200+ XP
will the xp90 fit your board ? if so just get that with a panaflo L 92mm fan
D
I have no idea, I actually dont have the board* or cpu yet, but some guy on dfi-street is selling me them on the 1st of the new year..
I saw the sticky up top recommending the MASSCOOL, and that thermalright one. Would the MASSCOOL work for overclocking? I heard it isnt such a great cooler from newegg reviews..
dchrsf said:
I have no idea, I actually dont have the bored or cpu yet, but some guy on dfi-street is selling me them on the 1st of the new year..
check TRs page for compatibility
D
N H O, would that work passively? I couldnt find anything in Thermalright's site saying anything but that it was rated for a Athlon XP 2800+ and higher. I'll just go with a L1A if not. My other concern was whether it would fit into my motherboard I will be buying..
if you want to run it without a fan look at the TR HR1
D
SI-97A + an undervolted 92mm Panaflo Low-Speed.
The new HR-01 won't work on Socket A boards.
