I like my machine quiet. I have some super-quiet Noctua 120mm fans, and my CPU cooler is a Scythe Zipang 2 on my Phenom II. A couple weeks ago, I got a Radeon 4870 on Newegg to replace my 8800GT, and while it's not bad at idle, it's a freaking vacuum cleaner under load.
I've been hunting for a good (active) cooler for it. I know the Zalman VF1000 is recommended widely, including by [H] but my (limited) experience with Zalman heatsinks and fans is that they're not really as quiet as they claim. At one point I had a 9500 in a system, and the only way I could get it to cool adequately (an E6600 OC'd to 3.2GHz) was if I turned up the fan until it was unacceptably loud.
Does anybody who shares my insane passion for silence have an aftermarket cooler on your 4870? How does it do? Did you need to make any modifications?
EDIT
I found the T-Rad2 and I think it'd fit the bill with some quiet 92mm fans or maybe another Noctua 120mm. What I need to find out though is do I NEED to buy the VRM cooler? That puts the whole cooling solution somewhere around $90. For that much, I might just take a chance on a VF1000 and its like $8 add-on for the VRM.
EDIT
