Quiet Pump/Res combo?
The Swiftech MCP355 and MCP655 are really quiet in my experience. Fans are usually louder than the pumps.
Kind of funny that you can get the reservoir with a pump for less than the reservoir without it.
I'm also thinking of getting a second reservoir for extra water capacity. Will this help temps significantly?
Thanks, does anyone make a nice 5.25" reservoir for the D5 (655)?
Edit: Found one
http://www.frozencpu.com/products/1...55_w_Blue_LED_Light_-_Clear_Silver_Black.html
I have that res and its really nice. The only downfall is there is no way to adjust the pump speed without pulling out the res and trying to fish something up to the pump speed control or actually removing the pump. The loudest part of my loop is that stupid pump because I set it to 4 and am not about to drain the loop to take out the res and pump to turn it down.
That res/pump are loud at first until it clears out all of the air. Takes about 24 hours.
