AuroraProject
- Dec 13, 2004
I'm looking for a quiet power supply for around $100. I am currently considering two models: an OCZ Modstream 520 and PC Power & Cooling Silencer 470. Any thoughts on other models I should look at? If it helps I will be powering the following:
Asus P4P800-E
3.06ghz P4 533fsb w/ XP-90 & Panaflo H1A fan
ATI 9700 Pro
Audigy 2 ZS
Orange Micro USB 2.0 expansion card
Happauge TV tuner card
2-120gig Seagate 7200rpm IDE hard drives
2-400gig Seagate 7200 rpm SATA hard drives
1-74gig Raptor SATA hard drive
all in a Lian Li PC-7077B case (dual 120mm & dual 80mm fans)
Edit: I'm also concerned that the Modstream cables may not be long enough for use in a full tower case, any thoughts?
Thanks.
Asus P4P800-E
ATI 9700 Pro
Audigy 2 ZS
Thanks.
