Quiet LGA775 HSF?
mikeblas
[H]ard|DCer of the Month - May 2006
What's a good LGA775 HSF? I'm more worried about noise than CPU temperature, as I don't overclock (much).
I found some reviews at Overclocker cafe, but they're poorly written and don't give me much information. From the three there, I would go with the Thermaltake Silent LGA775, I think.
Has anyone here used a Dynatron P12? It's passive, and I can't believe it would be good at cooling an aggressively used Prescott. Their P21 looks neat, but I'm worried it will be loud.
What about this TR2TT A4013-02 ? It went out of stock; is it worth waiting for? Is it made by TR2TT, or Thermaltake? The NewEgg listing says it has a 3-pin power connector; don't LGA775 boards have a four-pin connector on the motherboard for the fan?
How much better is the 7000 than the 7700? They're not listed as LGA775-compatible at newegg; what doodads and adapters do I need to buy to make 'em work?
no no no, hte 7700 is better, its a 120mm version instead of 90mm of the 7000, but the 7700 wont fit on my board (neo2)
i believe there is a little adapter for the 7000 to fit on LGA, as it came out before teh LGA socket, and the 7700 is native
OK, I found 'em up at the Frozen CPU site.
Thanks for the clarification! Indeed, the 7000 doesn't have the adapter; the adapter for it looks like a real hack. The 7700 has a backplate and a much more sensible-looking mounting solution.
The only thing I don't like about the 7700 is the fan itself. If I get something like an XP-90, the fan is easily replaceable with any fan of the proper size.
How would I replace the fan in a 7700?
Good idea. The stock Intel fan can drive you crazy. Here's a couple of other options.
I'm going to try the Nexus PHT-7750. It clips in using the standard mounting holes as opposed to using a mounting bracket under the motherboard.
I just wish it would ship already!
http://www.endpcnoise.com/cgi-bin/e/PHT-7750.html
The Arctic Cooling Freezer 7 also looks good for a regular clip on unit. I might get that if the Nexus doesn't ship soon.
http://www2.newegg.com/Product/Product.asp?Item=N82E16835185116
No kidding!!1! The Intel HSF is so whiny, I can't believe their isn't revolt in the streets.
The Nexus looks nice; thanks for the link.
My only hang-up (with both the 7700 and that Nexus) is that the fan isn't shielded. The Nexus has the same problem. It sounds dopey, but if the fan isn't covered, I find that any time I tinker in the case a cable or wire gets pushed into the blades and I want to avoid that.
I'll probably go with the Zalman CNPS7700-ALCU.
