Quiet HTPC
PhantmShado
I'm looking to create a quiet htpc for the bedroom, tried a mitx, but the noise level on the thing is way too overpowering in the 12x12 room, and it's ended just sitting unused along with the rest of the setup. My goal is streaming hd video (1080p mkvs off my nas, as well as Amazon Instant video, Twitch, so forth). That's all it needs to do
I do not have one, my assumption is I'd be willing to pay as much as it costs. Pretend the budget is $1000 if you need one.
Seattle, WA, USA
CPU (I assume on board video here will be enough), RAM, mobo (w/HDMI port), case (tower preferred for the space I have), Aftermarket cooling (new case fans, heatsinks, whatever will get me quiet and able to deliver my goal), PSU
The SSD at http://www.newegg.com/Product/Product.aspx?Item=N82E16820226247
6) Will you be overclocking?
No
1920x1080, 40in
ASAP/black friday sales (still want the best bang for my buck)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
hdmi
Yes, 64bit windows home premium
Thanks!
Before everyone starts recommending a system, can I ask what exactly your mITX rig consists of? Components including case and fans?
Because, depending on what you have already - if it is new enough hardware - you may be able to quiet it down and/or get away with a few new components rather than a whole new system.
Also, just in case you aren't familiar with them, silentpcreview.org is a great resource for quiet computing. Not saying that the enthusiasts here at [H] won't be able to help because of course they probably will be but the entire SPCR site is dedicated to quiet computing.
Check out the HTPC in my sig, I seriously cannot hear it at all after adjusting the fan in the BIOS.
There's no fans listed for your htpc in your sig, what fans are you saying you adjusted in bios?
