Hi everyone,
I've built various gaming and budget desktop PC's, but this is my first time putting together a SFF/HTPC, so I would like some feedback on the parts that I've picked out after a bit of research:
I'm hoping to control the audio/video players with either a remote or using VNC from my Android tablet
CPU $130: AMD A10-5700 (3.4GHz, 4C, 65W TDP)
MoBo $140: Asrock FM2A85X-ITX. Must be M-ITX form factor.
RAM $50: G. Skill 2x4GB DDR3 1866 Ares
SSD $100: Samsung 840 128GB
Case $72+$24: Wesena HTPC-ITX4 with remote
PSU $70: PicoPSU 150XT with 150W adapter
OS $100: Windows 7 Home Premium 64bit OEM.. not sure about Windows 8 as I've only tried it briefly at work on tablets..
Total: $686 before tax/shipping
Optional
CPU Cooler $46: Noctua NH-L9a Doesn't seem to work well with Asrock mobo
Thanks!
Optional
Thanks!
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
1. Audio player (songs on external HDD, external DAC, amp and headphones)
2. HTPC (play dvd/bluray rips on external HDD and perhaps NAS in future)
3. Light gaming (Diablo 3, Starcraft, Pro Evolution Soccer series)
2. Will you be overclocking?
No
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
$500-$1000 CDN including tax+shipping
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
Toronto, Canada
Canada Computers, NCIX, Tiger Direct
5. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, MoBo, Case, RAM, SDD, PSU, OS
If budget fits:
Aftermarket CPU cooler (mainly to have less noise than stock cooler)
6. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
None
7. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
Required: Optical S/PDIF out, SATA 6Gb/s
Wanted: USB 3.0, 1 PCIe expansion slot (for half height TV tuner card if necessary)
8. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
1080p, single monitor via HDMI/DVI
9. Does this system need to fit into a particular space and do you need an optical drive? Think entertainment center shelves, closet space, rackmount, etc. Many modern SFF cases have either removed the optical drive or have been constructed so that removing the ODD increases the configuration possibilities immensely.
Looking for small HTPC case approximately in this size: (w x d x h)
250mm x 250mm x 100mm
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
Prefer not to do any mods
11. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
Towards the silent side, hoping to go with 1 quiet HSF and maybe 1 exhaust fan
12. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
Does not need to be mobile.
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
No
14. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
In the next 1-2 months
By answering these questions you help us help you build a PC that's of better quality, better performing, cheaper or all of the above. The more details the better responses you will get.
