Quiet down a MSI TI4600
Deadlierchair
I posted about using the zalman heatpipe solution, but since that won't fit...
I'm using the stock heatsink/fan and added 1 cm ramsinks to all of the ram chips. The fan is really quite loud, so I would like to use something quieter. With the Zalman not an option, and the VGA silencer not compatible...kinda makes things difficult. Aside from hacking old CPU heatsinks and adding those, what are my options? I know the TI4600 is a semi-old card..but I'll have it for a while and I want it to be a little more tolerable as far as noise.
position a couple 80mm fans to blow over it, or whatever size you want. unplug /remove stock fan.
what the heck?! LOL!! who resurrected this thread?!?
