Okay, so i installed Quicktime by itself, and not i need Quicktime installed.
I used the uninstall feature to uninstall Quicktime the usual way.
I then proceeded to install the iTunes/Quicktime install. Once i am almost all the way done with installation, it gives me this error.
"The Older version of Quicktime cannot be removed, contact your technical support group."
2nd error
"The installation of Quicktime did not complete successfully. iTunes requires Quicktime."
So i proceeded to remove the folder manually. Then I also went into the registry and completely removed the "Apple Computer Corp." folder that included Quicktime in it, and i also removed all traces of Quicktime in all the "HKEY" Folders.
I have also tried to use the fancy uninstall software, mainly "Ashampoo UnInstaller Platinum 2"
What do i do? I have tried everything i can think of.
Thanks [H]ard community!
2nd error
