This is not the run of the mill software request.
We have about 20TB on various storage arrays that hold hundreds of thousands of folders. Inside those folders are millions of tiny files in the range of 2KB or so.
This is encrypted file storage for offsite backup.
We run a program currently called "dirsize" that allows us to automate scanning all these folders and reporting to a text file how big all the folders are. (IE, 212GB, or 345GB, etc)
Problem is the program goes through and scans every file in every folder similar to how right click on a folder in windows does. However with so much data now the scans are taking almost 24 hours of constant scanning.
Is there an easier way that is automated? We don't need to be SUPER accurate. I mean. anything that would get us within plus or minus 5% would be acceptable.
It must be able to be automated or scripted, and must output the results to a text file or spreadsheet of some kind.
Does anyone know of a program that will fit our needs?
