tbonepat11
- Dec 2, 2001
AMD X2 3600+
ASUS M2N-SLI Deluxe
4 gb(4x1gb) DDR2
PNY 8800gtx 320mb
74gb Raptor/750gb WD GP 5400-7200
Current system is listed above. I am looking to upgrade and focusing mainly on the motherboard/processor.
-The main purpose of the system to be used for gaming and multi-media.
-Price range $200-$400. Lower is better obviously but if a huge step up will cost me another $30, so be it
-Overclocking is not really a main concern at the moment. I have heat issues in my 3rd floor townhouse room and I run air cooling.
I was considering an E8500 coupled with http://www.newegg.com/Product/Product.aspx?Item=N82E16813128345 or something of the like.
I have not kept up with processors and mobos as much in the past 6 months so I might be out of the loop. Plus I have never gone Intel before so generally know a little less about their products as compared to AMDs.
I appreciate the help in advance and am open to any suggestions to either CPU/Mobo or any other aspect of the system.
ASUS M2N-SLI Deluxe
4 gb(4x1gb) DDR2
PNY 8800gtx 320mb
