Quick upgrade question for you qurus out there ...
Kurse
Current setup:
- AMD Athlon 64 3500+ Processor S939 Venice 2.2GHZ 512K L2 Cache 90NM Retail Box
- ASUS A8N-E MOTHERBOARD ATX S939 NFORCE4 ULTRA
- Arctic Cooling Freezer 64 Pro S754 S939 S940 2200RPM 40CFM Heatsink Fan
- OCZ Premier PC3200 1GB 2X512MB DDR400 x 2
- BFG GeForce 7800 GT 256MB 256BIT GDDR3 PCI-E Dual DVI-I HDTV VIVO SLI Ready
- ANTEC NEOPOWER 480W POWER SUPPLY ATX12V PS/2 DUAL 12V RAILS ACTIVE
- ZALMAN NB47J FANLESS NORTHBRIDGE CHIPSET COOLER
- Maxtor DiamondMax 10 200GB SATA 7200RPM 16MB 9MS FDB RoHS
- Maxtor DiamondMax 10 300GB SATA2 7200RPM 16MB 9MS NCQ Quiet RoHS
- Samsung syncMaster 930B
I am going to make an upgrade to my system and I'm wondering which route would be the best. (1, 2, or 3) and suggestions of course.
1. BFG GeForce 7900 GTX OC PCI-E 512MB GDDR3 SLI Ready Dual DVI-I HDTV
or
2. AMD Athlon 64 FX-60 Processor S939 Dual Core 2.6GHZ 2MB L2 Cache 90NM
or
3. BFG GeForce 7950 GX2 Dual GPU 1GB GDDR3 PCI-E Dual DVI-I HDCP HDTV
This is a gaming rig first and everything else second :)
Also, is it true that the new Creative Labs X-FI cards will actually help increase your FPS?
Thanks in advance ....
P.S. All of the above components were purchased due to excellent reviews from these forums!! Awesome place to get advice. (cept the memory ... had to cheap out somewhere)
Well your computer already looks pretty good.
If I was going to upgrade that, I would go with a dual core processor. Cause I multitask quite a bit.
But I wouldn't get an FX-60. For $250, you could get an x2 4600 which is only 200mhz lower than FX-60, and less than half the cost.
Of course that second core won't help too much for most games...
-Athlon 64 FX-60 Processor S939 Dual Core 2.6GHZ 2MB L2 Cache 90NM - $790
-Athlon 64 X2 4600+ Dual Core Processor S939 Manchester 2.4GHZ 512KBX2 90NM - $308
ya .. big difference in price. I could get a new X-FI sound card as well. Didn't know the difference was soo little in speed.
get an evga 7900 gt ko from newegg.
that and an x2 4600 will leave you with about 200 dollars.
btw, what are you doing with the 3500+?
Heh .. that processor goes into the wifies computer.
Processor and CPU. Looking into that now.
To be a bit more specific to my above question, 'm really looking to get a better FPS in BF2. Right now I run BF2 in 1280 x 1024 but I need to turn down some of the graphic options. I would really like to run it in 1280 x 1024 with all options turned on and at the highest setting.
- EVGA E-GEFORCE 7900 GT KO 256MB 256BIT 1.5GHZ GDDR3 Dual DVI-I - $324.50
- -Athlon 64 X2 4600+ Dual Core Processor S939 Manchester 2.4GHZ 512KBX2 90NM - $308
$632.50 sounds like a nice price point.
Not to confuse this more but what if i was to purchase a SLI Board and another 7800GT?
i dont know about sli, but my friend has an evga 7900 gt ko superclocked, and he can play counterstrike source, halflife 2, and day of defeat source with every setting turned all the way up, and still maxes out all of the FPS.
The monitor you have only runs at 1280x1024 correct? Given that, the 7950 GX2 is a not a good buy. The FX series processors also will do nothing extra for gaming. At this point my recommendation would be to wait for DX10 cards, but if you must buy now, get the best price/performance 7900 series card you can find.
Of course a dual-core CPU upgrade would do wonders for general computing, but if you insist this rig is only for gaming, the vast majority of games still don't optimize for dual-core.
Ya, 1280 x 1024 and after reading review after review of all the cards I was considering the 7950GX2 would be overkill for my system and I wouldn't even see the full benefit due to my processor.
I started looking at the x1900xt and was sounding like an excellent idea, especially considering the price. However since I am one of those "noise wussies" i'm staying clear of it.
So it looks like a processor upgrade, Athlon 64 X2 4600+ (Dual core is the smartest way to go I see), and some type of 512MEG 7900 GT card will fit the bill nicely. Of course now I need to research all the 7900 GT cards to find the best one. (eVga or BFG probably) Back to the forums !!
So this one
- EVGA E-GEFORCE 7900 GT KO 500MHZ PCI-E 256MB 256BIT 1.5GHZ GDDR3 Dual DVI-I HDTV Out RoHS - $324.50
or go for the 512meg version
- VGA E-GEFORCE 7900 GT KO 560MHZ PCI-E 512MB 256BIT 1500MHZ GDDR3 Dual DVI-I HDTV - $457.80
If I may offer some advice here, I would say wait for a DX10 card. the performance increase you will see going from a 7800gt to a 7900gt is minimal at best imo. I mean yes theres an increase but hardly worthy of you cash at this point in time. So not worth it dude. Spend the same money on an equalivalent dx10 card in a couple of months and get alot more for your money. Besides, I doubt yout hurting too much in the eye candy department with the card you have now, correct?
True enough. After looking around I'm starting think that my processor is causing the bottleneck. I have a feeling that if I just upgrade my processor right now I will be able to turn my settings up to max in BF2 and wait for the DX10 cards to come out.
Hmm .. this is interesting though.
Futureshop.ca has the BFG 7900GT 256Meg. card on sale.
Our price: $429.99
Discount: $110.00
Sale Price: $319.99
Mail-in rebate: $50.00
After rebate: $269.99
If i get thier Service Plan on this for $50 it covers it with instant replacement for 2yrs.
That plus the processor is sooo tempting. I should also mention that I have someone who is going to buy my old 7800GT for $200. He already has one and wants SLI.
err ..scratch that. Must be patient and hold out for a better version.
Kurse said:
Oh man ... the research goes on. Finding this discussion doesn't leave me with a warm fuzzy fealing for the 7900 series though.
GeForce 7900 Inferno
The new revisions (the ones that say RoHS or HDCP) don't have the issues of the earlier cards. After 2 rma's I finally got a pair of good 7900GT KO Superclocks to run SLI and I'm very happy....above single 7950GX2 performance.
