- Sep 6, 2007
I just bought a small Shuttle barebones system from a fellow forum member, and that leaves me with a heat-related question. I'm planning on using this as an HTPC to replace a full tower in my living room. I have a choice of two processors, and I'm wondering which would generate less heat.
The options are a Core 2 Duo 6420 and a Core 2 Duo 8400.
Thanks!
Thanks!
